Puh rod out of Position - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 25th, 04, 03:04 AM Thread Starter
Recently I put in a new Cam & lifters But the pushrod and rocker arm pops out of place every once & a While. Why?
funky is offline
post #2 of 5 (permalink) Old Dec 25th, 04, 05:29 AM
pushrod is bent... spring is broke... lifter is colapsed... cam lobe is wiped... pushrod / rocker not located properly?
only one? while it's running?
post #3 of 5 (permalink) Old Dec 25th, 04, 06:00 AM Thread Starter
the pushrod is nt bent and spring isnt broke and so is lifter
this happens while its runningit could be the cam but i just put in a cam so is it that because i postive the the push rod and rocker is in position correctly?
funky is offline
post #4 of 5 (permalink) Old Dec 25th, 04, 12:41 PM
is it adjusted properly?
does it tick when it runs before it falls off?
are the pushrod and rocker arm worn out?
does the adjuster nut back off- if it spins on easliy without a wrench, it's time for a new nut.
you don't plan sincerity.
novaderrik is offline
post #5 of 5 (permalink) Old Dec 25th, 04, 12:50 PM
Chad
67 Plum's Avatar
If you dont have guide plates check the push rod slot in the head.It should be straight on the sides to locate the push rod and rocker arm. I have seen them worn out before. If the slot is worn you can get self guided rochers and put on as a temporary fix.
67 Plum is offline
