Backfires under hard acceleration - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 2nd, 04, 11:37 AM Thread Starter
Send a message via AIM to Samuel
Hey, i replace my intake manifold and carburetor a little while ago on my 67 camaro (350 c.i.). I just found out that when I floor it or accelerate quickly, there are some little backfires that come out of the carburetor. I am currently running a 650 speed demon carburetor with a vaccuum secondary. Can anyone explain what I might have to do to prevent the backfiring?
Thanks, Samuel
1967 Camaro SS. See pictures of it here: <a href="http://community.webshots.com/user/sbwell1020" target="_blank">http://community.webshots.com/user/sbwell1020</a>
Samuel is offline
post #2 of 7 (permalink) Old Oct 2nd, 04, 02:41 PM
MJM
Maurice
Check for a flat lobe on the camshaft, your discription is text book for this condition. [img]graemlins/sad.gif[/img]
MJM is offline
post #3 of 7 (permalink) Old Oct 3rd, 04, 06:15 AM
Angry
What intake and carb did you have on your car before you changed? What intake did you replace the old one with? Sounds like you could be running a touch on the lean side. That will give you popping from the carb as well. Any other details of your combo and your tune-up always help.
bravewink is offline
post #4 of 7 (permalink) Old Oct 3rd, 04, 08:18 AM
Eric
1. Ignition. Check your cap, rotor, wires and plugs to make sure you have a strong spark.
2. Too Lean. While you are checking the plugs look for little black specs on the insulator. If you see them you have some detonation and the engine may be running too lean or you have too much timing. If the insulator is pure white than that is also a good indication you may be too lean -- common this time of the year with good fall air.
3. Flat Lobe. Pull a valve cover and look to see if there are any loose rocker arms of rockers that don't move up and down as much as the others when cranking the engine.
Eric68 is offline
post #5 of 7 (permalink) Old Oct 3rd, 04, 09:38 AM
Harry
dawg's Avatar
check for vacum leak around the intake.
434 stroker
US Navy retired
dawg is offline
post #6 of 7 (permalink) Old Oct 3rd, 04, 12:22 PM Thread Starter
I was previously running a stock intake manifold and stock rochester q-jet 4bbl. I replaced them with victor jr. and 650 speed demon vac. secondary.
Samuel is offline
post #7 of 7 (permalink) Old Oct 3rd, 04, 01:51 PM
Eric
You might have to play with the accelerator pump calibration to get it to leave without popping back (if that is the problem). You might have to go with a smaller accelerator pump squirter . . . if it has a #31 try using a #28.
Is the rest of your engine stock? What other changes have you made to the motor?
Eric68 is offline
