How do I find out my pistons or compression? - Team Camaro Tech
post #1 of 10 (permalink) Old May 10th, 04, 11:50 PM Thread Starter
Ok so right now I have a fairly stock 350 that I was told is out of a 86 blazer. I have some 62cc trick flow heads, Kenny Duttweiler 23 degree heads, 195cc intake 2.02 intake valves 1.6 exhaust. I am concerned about trying to put these on my motor because I dont know if the compression is going to be to high or what? So what can I do to find out what the pistons are or compression? Without having to pull the motor apart. I really dont want to have to pull it down to find out I should just go ahead and build my new motor instead of trying to bolt on these heads.
Thanks guys
Zack
<A HREF="http://home.austin.rr.com/spinya/car/" TARGET=_blank>http://home.austin.rr.com/spinya/car/</A>
Zack67 is offline
post #2 of 10 (permalink) Old May 11th, 04, 02:11 AM
Smile
Take the number-letter codes off the pad right above the pass. upper water pump bolt or right in the top middle of the block above the water pump and post them here or over at the "TAG" section and at least you will know what it originally was unless the block has been decked.
Thuis will do for starters b/c if it has been changed you may have to get inside it and look??
pdq67
post #3 of 10 (permalink) Old May 11th, 04, 07:40 AM Thread Starter
Ok the numbers are
V1025ZAK
1AS404025
Thanks I really appreciate the help.
Zack
Zack67 is offline
post #4 of 10 (permalink) Old May 11th, 04, 08:09 AM
Smile
I will look it up tonight when I get home for you in my big motor book..
Later, pdq67
post #5 of 10 (permalink) Old May 11th, 04, 08:26 AM
Robert
Worst case you shouldn't have too much static compression. But a stock cam with those heads could yield too much dynamic compression.
Robert
TC member #18
rojo is offline
post #6 of 10 (permalink) Old May 11th, 04, 09:14 AM
Royce
Do you have the casting number off the rear of te block, drivers side right above where the tranny bolts to the engine. With this we can see where the engine came from. Also if you get the head casting numbers (you have to take off the valve cover) we can see what size chambers the current heads have.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 10 (permalink) Old May 11th, 04, 12:17 PM
Sorry, my copy of "Ultimate American V-8 Engine Data Book 1949 to 1974" doesn't go up new enough!!
OK guy's, what type and year vehicle's a 350" "ZAK" motor out of??
Got any takers??
Thanks in advance..
pdq67
post #8 of 10 (permalink) Old May 11th, 04, 12:21 PM
ZAK = 1980 350, 190hp, Corvette
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #9 of 10 (permalink) Old May 11th, 04, 09:57 PM Thread Starter
Ok so I have a 80 vette motor? So can I just bolt on these heads? Or am I going to have too much compression? What are my options?
Thanks again
Zack
Zack67 is offline
post #10 of 10 (permalink) Old May 12th, 04, 02:16 AM
Smile
Zack,
Go over to the ROSS Racing Piston site and input your motor's spec's and it will tell you.
I use .025" down in the hole for the piston depth to the top of the deck then whatever headgasket thickness you want to use from .015" and .022" shims up to .038" and .040" composite headgaskets thicknesses.
Shoot for a quench of about .040" to .045" and you will be right in there.
I don't know your motor so can't help with piston type be it a four valve notch flat-top at about 4cc's or a dish of some kind so you will need to do some homework there to figure this out. I think dishes go up to 12 maybe 16 cc's but really DON'T know???
Also go over to Pat Kelley's great "Dynamic Compression Ratio Caculating site and read up on it. You can input different cams spec's to play with it.
All this is a hoot to me b/c I play around with both programs for the fun of it...
pdq67
