BW T-10 Input Shaft question... - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 14th, 01, 08:48 AM Thread Starter
I just pulled this tranny out of a 1980 Z/28 and I noticed that the input shaft has a little bit of play to it. There is approx 1mm of travel from on extreme to the other in all directions. Is this normal?
If it's not normal what should i do about it?
Thanks!
msquared is offline
post #2 of 5 (permalink) Old Mar 14th, 01, 09:07 AM
There is always a little play in the front bearing. Since you have it out they are not hard to change and if the tranny has many miles on it it's probably bad.
oger is offline
post #3 of 5 (permalink) Old Mar 14th, 01, 09:21 AM Thread Starter
The tranny was rebuilt (all bearings, seals and warn gears) 15,000 kms ago... so it's fairly new. I was thinking about cracking it open and taking a peak inside anyway though...
msquared is offline
post #4 of 5 (permalink) Old Mar 14th, 01, 01:10 PM
Freddie
The input shaft will have play in it. It relies on the pilot bushing in the crankshaft to stabilize it. This is why it is important that you have a good pilot bushing.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #5 of 5 (permalink) Old Mar 16th, 01, 04:41 PM
JohnZ's Avatar
Better yet, a good pilot BEARING - $12.00, and they last forever.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
