conversion - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 23rd, 00, 08:18 AM Thread Starter
i want to put a 350 and 6 speed trans out of a 99 camaro ss with all the computers and wiring harness's into my 82 Z-28 if you have any information on this conversion please contact me thanks
rmaclean is offline
post #2 of 4 (permalink) Old Dec 26th, 00, 07:44 AM
Cool
You will have to move the shifter over to the left, about an inch or so. So you can get in every gear. Just fabricate a block and mount it at the bolt that connects the shifter to the tranny. You will also have to fabricate a new crossmember for the tranny. I don't think anybody makes them yet.
RODS92 is offline
post #3 of 4 (permalink) Old Dec 26th, 00, 04:29 PM
Not only that, but you need a custom bracket for the hydraulic clutch, you need a custom oil pan, custom engine brackets, custom headers, ect... Will cost around 7000 all said and done.
edit:
Duh, i didn't notice the year of the car. ignore me.
1968 RS/SS Camaro w/ 94 vette LT-1 and T56 six speed, Cal-Tracs, Baer 12" crossdrilled brakes 17" rims, ect....
<A HREF="http://home.earthlink.net/~speedracer68/tyler.htm" TARGET=_blank>
My 68 with LT1 and T56</A>
[This message has been edited by Teetoe_Jones (edited 12-26-2000).]
Teetoe_Jones is offline
post #4 of 4 (permalink) Old Dec 27th, 00, 06:37 AM
You can buy and aftermarket crossmember for you 82'. Thats what I used. It was bolt up and took a lot of work out of the project. As for the shifter. You cut the shifter hole in the floor pan back about another 2 inches. Thats it. The stock shifter will work fine.
Standard LT1 Camaro accessories will fit the 3rd gen chassis, but a little notching is required on the crossmember.
My question though is the 99 Camaro. Aren't those LS1 cars? If so, all bets are off and you are on your own. EVERYTHING is different. The LS1 is not a standard small block, so the motor mounts will have to be made. The trans will not bolt to a standard small block either. Its an all or nothing deal.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
