Duh - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 15th, 03, 09:34 AM Thread Starter
Denis
I just realized that I neglected to block off a threaded hole on the front of my block, near the fuel pump. See the highlighted bolt on the photo from the 67 AIM below:
Duh. [img]graemlins/clonk.gif[/img]
This wouldn't by any chance help explain why I'm only pulling 6-8 lbs of vacuum at idle at the manifold, would it?
deejaygee is offline
post #2 of 5 (permalink) Old Jul 15th, 03, 09:43 AM
Kevin
KevinW's Avatar
Talking
Sorry, that bolt would explain the oil leak [img]smile.gif[/img] from the front of your engine.
Sometimes the hole was not drilled all the way through. Also, don't put too long of a bolt in, you can hit the fuel pump rod with it and really mess things up.
Kevin
Kevin
KevinW is offline
post #3 of 5 (permalink) Old Jul 15th, 03, 02:24 PM
Smile
And that should be one of the two, (two on each side), bolt holes that are for the original front mounts that the tri-fives used! pdq67
post #4 of 5 (permalink) Old Jul 15th, 03, 03:22 PM
Those are also used as smog pump bracket holes on the passenger side. The other side can be used for power steering pumps on vans and other uses too.
-Mark.
stingr69 is offline
post #5 of 5 (permalink) Old Jul 16th, 03, 11:08 PM Thread Starter
Denis
FWIW, the correct block-off bolt is 3/8-16x3/4", Grade 5 with a small 'c' on the bolt head.
