P/S Pump compatibility - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 11th, 05, 01:32 AM Thread Starter
Sorry if this is in the wrong area, closest i could find and this is my first post!
I got a 1984 Camaro, 305 Small block engine, i have the oppertunity to replace my hole ridden power steering pump very cheaply, but it would be with a pump from a 1967 camaro with a 350 engine, it looks the same, the mounting brackets appear to be the same also, just wondering if anyone knew for sure if the pump is compatable.
Many thanx!
Awesome_Bryan is offline
post #2 of 4 (permalink) Old Jan 11th, 05, 03:59 AM
I'm not positive of the year it started, but they went to metric reverse flare fittings around then. Check the pressure fitting on the pump very carefully. You may be able to swap fittings with the old one,
What's cheap? I'd think an early 80's gm pump would be extremely cheap in a junkyard.
And btw, welcome to TC!
post #3 of 4 (permalink) Old Jan 11th, 05, 06:08 AM Thread Starter
Cheap is $10, but the original didnt have A/C, mine does, was told it will cause a problem. Have no idea how, im not a mechanic only ambitious. Think i wont take the risk.
Local garage have quoted me £65GBP for a new one. Thats a lot more than $10!!
Thanks for the help!
post #4 of 4 (permalink) Old Jan 11th, 05, 03:28 PM
Sorry, Bryan, didn't see you were in England, guess you don't have too many junkyards full of old american iron.
