What should I do? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 5th, 05, 04:04 AM Thread Starter
Garry
Well, I pulled the 302 out of my Z mainly for cleaning and to confirm all the parts are correct. So far so good. Now that I have it on an engine stand I guess I need to confirm everything is in good working order. Should I do a compression check? Did not do it while it was in the car. Leak down test? Have the heads freshened up? How far should I take it?
'69 Z/28 Garnet Red
'66 Chevy II Nova SS L79 (project)
'68 Z/28 Matador red
grag is offline
post #2 of 4 (permalink) Old Jan 5th, 05, 04:29 AM
Brandon
If your going to put a different motor in, then rebuild it and set it aside in your garage. If it's going back in, rebuild it, while its in the machine shop clean up the engine bay.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 4 (permalink) Old Jan 5th, 05, 07:23 AM
If I'm remembering from your other posts, you're just doing an underhood clean & detail?
If yuo've had no problems with the motor, and it doesn't need a rebuild, there isn't a lot to do.
Clean & paint of course.
Replace any leaky gaskets.
Check the clutch, replace the throwout bearing even if everything else is still good.
Great time to adjust the valves.
post #4 of 4 (permalink) Old Jan 5th, 05, 08:14 AM Thread Starter
Garry
I have decided to freshen the motor up while I have it out. It doesn't appear to need much.
thanks!
'69 Z/28 Garnet Red
grag is offline
