which motor mount goes on which side - Team Camaro Tech
post #1 of 5 (permalink) Old May 1st, 04, 03:44 PM Thread Starter
I am putting the motor together and grabbed the motor mounts and found they are different. Is there a way to tell which one goes on which side? I did the search thing but did not find anything. Thanks for any help
sudo1a67ss350 is offline
post #2 of 5 (permalink) Old May 1st, 04, 06:39 PM
Smile
For frame mounts..
I didn't think you could flip them b/c they bolt on with three bolts and should have a flange that goes over the lip of the X-member??
Anyway, I figure the tall one goes on the drivers side to tilt the motor up away from the steering box..
For rubber mounts, same as just above..
pdq67
post #3 of 5 (permalink) Old May 2nd, 04, 09:48 AM
Denis
The driver side frame mount should have a hole drilled through it to attach the clutch return spring.
deejaygee is offline
post #4 of 5 (permalink) Old May 2nd, 04, 01:33 PM
Smile
Cool, never looked that close..
pdq67
post #5 of 5 (permalink) Old May 2nd, 04, 04:18 PM
If they have GM part numbers, odd numbers are usually for the left side.
jimfulco is offline
