454 External balanced - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 29th, 05, 02:22 PM Thread Starter
Bob
Hi all
I am going to start installing 454 soon. I found out that 454 might be externally balanced.
1. Is there a code on the engine to tell me if it is internal or external balanced or what do I look for to tell me which it is. The 454 was in a 74 Chevy 3/4 ton pickup with Auto Trans. Flex plate looks like it is counter balanced.
2. I am installing in front of Toploader tranny is there a 454 balanced Flywheel I need to look for.
Thanks in advance
MT
Bob
______________________
68 Convertible 454 4 speed
MT 68 conv is offline
post #2 of 11 (permalink) Old Jan 29th, 05, 02:56 PM
Not 100% sure but I think all 400SB and 454BB are externally balanced.
georgia 69 is offline
post #3 of 11 (permalink) Old Jan 29th, 05, 02:57 PM
Chad
67 Plum's Avatar
All 454 are externally balanced unless they have been internally balance by a machine shop.You need a 454 flywheel.
67 Plum is offline
post #4 of 11 (permalink) Old Jan 29th, 05, 04:17 PM
you can use a regular flywheel if you get a counter balancer plate that goes between the flywheel and the crank. competition products sells them for $18.95 plus shipping.
19ynot52 is offline
post #5 of 11 (permalink) Old Jan 30th, 05, 08:16 AM Thread Starter
Bob
Thanks!
So am I correct in thinking that on install the weight on the harmonic balancer should be 180 degrees from the from the counter balancer plate. Let say harmonic balancer weight at 6:00 position and counter balancer plate at 12:00 position on the crank shaft.
MT 68 conv
post #6 of 11 (permalink) Old Jan 30th, 05, 11:24 AM Thread Starter
Bob
After looking at the engine I don't think that my last post is right. I now think the purpose is to counter balance the crank. Correct?
So new Question how do you establish the install position for the counter balance plate for a 454?
Should both weights be in alignment?(counter balancer plate and the harmonic balancer)
Sorry for the confusion.
MT 68 conv
Bob
post #7 of 11 (permalink) Old Jan 30th, 05, 01:07 PM
Angry
Try Midwest Motorsports too for the f/w balance plates!!
pdq67
post #8 of 11 (permalink) Old Feb 4th, 05, 11:55 AM
JohnZ's Avatar
MT 68 conv
The correct 454 harmonic balancer already has the weight, and is indexed to the crank by the key. The weighted 454 flywheel/flexplate is also indexed to the crank by the dowel pin in the crank and the extra hole in the flywheel.
[img]graemlins/beers.gif[/img]
JohnZ
CRG
JohnZ is offline
post #9 of 11 (permalink) Old Feb 4th, 05, 02:51 PM
Smile
Yes what John said and the blance plate mounts the same with a non-weighted flywheel to balance right.. (Use the crank flange's dowel pin hole as a line-up reference)...
And isn't the balance plate marked which side is "to flange" or something like that??
pdq67
post #10 of 11 (permalink) Old Feb 4th, 05, 05:46 PM
Bill
MT,
I know a lot of guys have used the balance plate without problems, but .... on a stick shift car I would not use it. Sort of like wheel spacers, the plate is a "band aid", not a true fix. Get the correct flywheel, they are not all that expensive.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #11 of 11 (permalink) Old Feb 5th, 05, 06:42 AM Thread Starter
Bob
Angry
Thanks guy's
That's what I needed to know!
Just doing a quick fix till summer. I will need a new clutch and flywheel soon. We just miss enjoying a short cruise now and then.
Thanks MT [img]graemlins/thumbsup.gif[/img]
