Help, cant get it to run? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 13th, 04, 10:05 AM Thread Starter
Whats new? I am trying to help out a friend right now get his car running. Just rebuilt engine (by a reputable builder), new Holley carb, and new MSD HEI distributor.
I got the engine @TDC last night(felt the air coming out of the #1 cylinder), checked the wires 3x and made sure there is fuel and spark.
The engine will not start but one hellva blast comes out of the tailpipe. It did this a few times as I was trying to rotate the distributor to get it to start. Usually when I start an engine for the first time I get a small "backfire" out of the carb while I am getting the timing right butit usually starts by the second or third try. And most of the time the engines will start. I never had a blast out of the tailpipe, so I'm kinda confused. Also I am used to the engine showing some kind of life after the first revolution or two, this engine turns over 10x or better before I get the gunshot out of the tailpipe.
I am fairly sure the timing @ the distributor is correct in relationship to TDC. Is it possible that I am missing something here? How about the timing chain being off a tooth or two? Any suggestions? Its his first car build and it'd be great to help him out but I never had this much trouble get an engine to fire over.
69importkilla is offline
post #2 of 4 (permalink) Old Oct 13th, 04, 10:45 AM
Sounds like the dist. is 180 degrees out of time
69 Big Block / Hugger Orange Sold
65 Chevelle SS
Black 2010 Electra Glide Classic
Branded is offline
post #3 of 4 (permalink) Old Oct 13th, 04, 02:58 PM
Bob
Check the valve adjustment and while you have the covers off check that you are at TDC for #1, both valves closed and reinstall the distributor if necessary.
[ 10-14-2004, 03:12 PM: Message edited by: phel69 ]
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #4 of 4 (permalink) Old Oct 13th, 04, 03:42 PM
Angry
Agree... that is the first thought that came to me. This is a good post on some thoughts for timing, because I'm fairly certain that is exactly what's wrong. Hope this helps:
http://www.chevyhiperformance.com/ho...38/index1.html
jethro is offline
