400 sbc - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 18th, 04, 12:59 PM Thread Starter
is a 400 sbc 3951509 2 bolt block a good block to build for a 68 camaro thanks
67rscamaro is offline
post #2 of 8 (permalink) Old Apr 18th, 04, 04:12 PM
Yes, a 509 2 bolt is probably the most sought after 400 block. Use it if it checks out at the machine shop. If it needs more than .030 over, sonic check it.
409SB, TH350, 12bolt 4.10<br />6.86 @ 98.8 on pump gas
Hals73RS is offline
post #3 of 8 (permalink) Old Apr 18th, 04, 08:31 PM
Sean
yep, as was said, a very good block. definately have it magnafluxed though. my first 400 block for my 406 build was a 509 block, but it had a hairline crack on the outside of the water jacket, it was very hard to even see.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 8 (permalink) Old Apr 18th, 04, 10:11 PM
OK, I have a 2 bolt main 400sbc(not 509), but what are the differences and/or advantages(I'm dumb)?
gmranch is offline
post #5 of 8 (permalink) Old Apr 19th, 04, 08:24 AM
A 509 or 511 2 bolt are the favorite 400 blocks of most engine builders. Both blocks could also be found in the 4 bolt variety but it's been said that they are prone to cracking in the main webbing. With that said, I have used and am currently using 4 bolt blocks and have never had one crack. Your 2 bolt block is the prefered block and is plenty strong especially if ARP main studs are installed. Also to add to the castings above was a 817 that I believe was only available as a 2 bolt. I've personally never used one but I've heard that it is the weakest/thinnest of all 400 blocks and should be avoided if possible. But if I had one, I'd try it.
Hals73RS is offline
post #6 of 8 (permalink) Old Apr 19th, 04, 10:39 PM
Thanks, for the info. My 400sbc block is a standard bore, 2bolt main "817". The motor is a mild fuel injected street motor, on pump gas, operating below 5500rpm. It is equipped with ARP main studs and rod bolts.
gmranch is offline
post #7 of 8 (permalink) Old Apr 23rd, 04, 12:40 PM Thread Starter
sorry for not getting back to u guys i really appreciate the info and i have one more question do the 509 blocks have steel cranks thanks
post #8 of 8 (permalink) Old Apr 23rd, 04, 02:29 PM
No, all factory 400 cranks are cast. But it'll be fine if machined correctly and balanced up to @ 450HP or so.
Hals73RS is offline
