Replace Engine Frame Mounts - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 4th, 03, 07:34 AM Thread Starter
Misha
Has anyone out there in Camaroland replaced engine frame mounts without engine removal? Just raise the engine by the pan?????
Thanks....
69 Camaro Z27
69ss350 is offline
post #2 of 2 (permalink) Old Sep 4th, 03, 07:57 AM
Hello, I've done it many times. As you said, raise the engine up enough, be careful with the fan hitting the shroud! Be SURE you support the engine well. Don't take any chances of it falling on your arms. Getting to the nuts inside the frame takes a swivel socket. It really isn't hard to do. Take care, Jeff
jeff1969rs is offline
