350 (Suggestions for moe power) - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 23rd, 04, 05:31 AM Thread Starter
I just purcashed a 350 engine and I was wondering how I could get a little more power out of it.I don't know all of the engine details but I can list all that I know. It has an edlebrock aliminum intake, 600 cfm edlebrock carb, headers, gm high performance heads, CR ration probably around 9:1. The guy figures it has around 300 horsepower. I was thinking about putting on roller rockers and adding a new cam. I want to run power brakes so I can't have to radical of a cam. Can someone make a suggestions to rockers and cam from comp cams that would be good for this combo. I would like a lobe sound to the engine.Also do I need need to run new valve springs, lfters etc. I am looking for the most bang for the buck. Thanks
Derek1 is offline
post #2 of 3 (permalink) Old Dec 25th, 04, 03:12 AM
What kind of exaust system are you planning on using and do u want a rough idle or smooth idle.Also are u using a stock torQe converter.and what type of lifters.
funky is offline
post #3 of 3 (permalink) Old Dec 25th, 04, 06:19 AM
Brandon
From Comp, the largest cam you can go to before having to rework the spring seats on the heads is a 270H pn# 12-211-2 or the 270S. They have a .470 lift with 270 duration. Couple these up with some 1.6 full roller rockers and you end up with .501 lift. I dont recall the kit to go with it, but call the tech support and they can tell you the correct springs. I want to say 853, but not sure. They are an oval spring so they allow more lift even though they are stock height. They ran about $140 I think. These will give you a nice lope at idle with a good mid to upper torque range. Full length headers will compliment by sublimenting the lowerend with more torque. Toss on a larger carb though, that 600 wont cut it. This cam also puts you on the cusp of just out of stock torque converters. So pick one up at 2400 that flashes to 2800 and your all set.
Brandon J. licence 1NASTY67
Nantooch is online now
