Brass Float - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 18th, 04, 07:37 PM Thread Starter
Lorne
I have a leaking brass float in my fuel sending unit on my antique Dodge. Will 2 part epoxy hold up to being submerged in gas?
MickyT is offline
post #2 of 8 (permalink) Old Sep 19th, 04, 02:44 AM
Not sure if it will. If the hole is small,could you solder it ?
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Sep 19th, 04, 06:57 AM Thread Starter
Lorne
I did solder it however the brass is thin and last time it cracked in a new spot so I thought I would coat the float with epoxy to strengthen it.
MickyT is offline
post #4 of 8 (permalink) Old Sep 19th, 04, 07:10 AM
Brandon
either the epoxy for nail polish will do.
Brandon J. licence 1NASTY67
Nantooch is offline
post #5 of 8 (permalink) Old Sep 19th, 04, 12:19 PM
Bill
Micky,
Have you tried looking for a float ? I have a pretty good source that has not let me down yet. E-mail me the year, engine size and carb number if you have one and I will see what I can find.
By the way, completely coating the float might add enough weight to it to keep it from working properly.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 8 (permalink) Old Sep 19th, 04, 12:30 PM
Bob
I would think that JB Weld would work fine if use sparingly.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #7 of 8 (permalink) Old Sep 19th, 04, 07:57 PM
Coat a nail with JB Weld and drop it in a small container of gas. If it looks good in a day or two, go for it. But keep the jar around. Check it from time to time. If the JB starts to break down, you'll know it's time to peak at the float. A little dab'l do ya.
dnult is offline
post #8 of 8 (permalink) Old Sep 19th, 04, 10:10 PM Thread Starter
Lorne
Installed it back in the Dodge earlier today. Gauge works again,I have to admit I never thought about the extra weight of the epoxy weighing the float down. Guess I will find out when I fill it up! If that fails I will send you an email BillK.
MickyT is offline
