TH 700 R4 in a 67 - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 22nd, 01, 08:34 PM Thread Starter
I am thinking about replacing my TH 350 with a 700R4. Will this rob more horsepower from my engine, or will it be a good swap? How difficult is this swap?
Cool Hand, aka The Great Cornholio
Cool Hand is offline
post #2 of 5 (permalink) Old Feb 23rd, 01, 04:42 AM
The 700 takes more horses to turn from what I understand, but I don't know about installation troubles. Also, I read your engine idea and I don't know if the 700 will be able to handle the power you are going to be putting out.
boodlefoof is offline
post #3 of 5 (permalink) Old Feb 25th, 01, 07:48 AM
Joe
Have you checked into a 200R4? I understand they can take more power. Supposed to be geared more evenly as well.
Check with Performance Transmissions since you are in SAC.
Just my .02
Joe
69 SS396 Clone, B&M TH400, 3.55 12 Bolt Posi, Blue w/White Z28 Stripes, Chrome Rally Wheels
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #4 of 5 (permalink) Old Feb 25th, 01, 08:29 AM
Daniel
Thumbs up
Hi,
I put a 2004R in my 67 and I love it. It was an easy swap. If you put a 700R4 in, you will have to shortend you driveshaft. The 2004R is the same lengthas the powerglide/TH350. The trans mount is differentthough. You will need to get and modify a TH400 cross member for the 2004R swap. There are a few other details but nothing to hard.
Daniel
67ss350camaro is offline
post #5 of 5 (permalink) Old Feb 26th, 01, 05:39 PM
The 200 is way too weak, forget about it. You can actually use the 350 mount but it's better to get a 400. YOU MUST be careful adjusting the TV cable, go to bow tie overdrives in Hesperia, they have a web site and advertise in all the mags. Steve there is truly fantastic. You also MUST use a lock up torque converter, otherwise it will overheat, something a 700 can't take. It is NOT a racing transmission, but can be lots of fun. I run a ZZ4 with a LT4 hot cam and 12 bolt 3:55, it will light them up through first and about 1/2 way thru 2nd. It'll cruise 70 @ 2,100. A great hot rod item.
sbarnes is offline
