starter grind - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 23rd, 03, 10:53 AM Thread Starter
Marc
i have a new mini starter from Tommy Johnson's motorsports warehouse, it is a gear reduction mini starter , 119$ . actually i installed it with all the different shims possible, either with and without the shims, and i noticed a grinding noise (starer teeth against the flywheel) when the starter engage and when it disengage, or even when it try to start the engine.
The starter is a universal application , as wheel for 153 and 168 fly wheels.
I realy don't know what to do. I am scared of ruin my fly wheel with that gringing.
It is really annoying.
Does anybody faced that and what did you do ?
Camaro 1968, propane 327ci, Big Brake, Hotchkis, T56
Marc is offline
post #2 of 4 (permalink) Old Aug 25th, 03, 05:01 AM
Josh
I have never heard of a starter that is good for both types of flywheels, I would check into this further.
J Early
J early is offline
post #3 of 4 (permalink) Old Aug 25th, 03, 10:18 AM Thread Starter
Marc
well that was written on the sheet i got with it. Anyway i count the teeth on the starter wheel and their are the same number then my original number. they look quite the same as well.
Really i don't understand what 's the problem and it is really annoying.
I think i 'll repair my old starter instead.
THe problem with the old unit is its solenoid that always burn because of the headers.
Marc is offline
post #4 of 4 (permalink) Old Aug 25th, 03, 01:52 PM
This will solve your problem for $29.95
REMOTE STARTER SOLENOID for GM Systems
and
Brian Lewis is offline
