Holley idles too fast - Team Camaro Tech
post #1 of 10 (permalink) Old May 9th, 04, 01:28 PM Thread Starter
I need some guidance with a fast idle problem on a Holley 670 Avenger carb on my 350. I am replacing a 750 Edelbrock on top of a Performer RPM manifold. This is a brand new carb that I just installed today, and it idles at about 2400 rpm. The curb idle screw is adjusted all the way out, and I backed off the fast idle screw on the choke also. Even with both screws out, it idles way too fast. The linkage seems to moving freely and not binding.
Any ideas where to begin?
Thanks,
68_SS is offline
post #2 of 10 (permalink) Old May 9th, 04, 04:29 PM
doesn't Holley give you some sort of an instruction book? i know my Edelbrock Q-jet came with a really comprehensive book that explained the theory of why a carb works and how to change different things to solve different problems.
you don't plan sincerity.
novaderrik is offline
post #3 of 10 (permalink) Old May 9th, 04, 05:34 PM
ZZ_430's Avatar
The secondaries have a stop too, it's a small screw on the bottom side of the carb.
Normally, new carbs don't need that adjustment, have you checked for vacuum leaks?
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 10 (permalink) Old May 9th, 04, 05:37 PM Thread Starter
It did come with an installation and setup manual, not really troubleshooting. I know I can download some stuff from Holley, but thought I could get some hands on advice as well.
68_SS is offline
post #5 of 10 (permalink) Old May 9th, 04, 05:38 PM
Bill
Brian,
SOunds like a vacuum leak. Double check and make sure you plugged all the vacuum fittings on the carb, especially the big one on the back. BTDT [img]smile.gif[/img]
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 10 (permalink) Old May 9th, 04, 05:47 PM
I had the same problem on mine recently. Turned out I hadn't given the linkage enough play to return to idle. What happens if you disconnect the throttle linkage all together? Otherwise I agree with ZZ430DropTop67RS. Check out the secondary stop. Should be between 1 and 2 turns out (your milage may vary). But if you get too far outside of that range I'd bet on a vacuum leak.
dnult is offline
post #7 of 10 (permalink) Old May 9th, 04, 05:49 PM
Steven
Some thoughts ... Even if the linkage moves freely does not mean that it is properly adjusted. Disconnect the linkage and start the car. This will either eliminate or confirm a linkage problem. Another thing to consider is the choke adjustment. Some carbs ( not sure about this one ) even have a 2nd adjustment screw on the passenger side that affects choke fast idle. I think you have an electric choke. If so, you need key-switched power and a ground. No power means extended choke engagement ... If choke canister has lean/rich adjustment, lean will make the choke release sooner. Are you using manifold vac for your distributor vacuum advance ? If so, that will kick up the idle by advancing the timing. Lastly, is this a problem with the air cleaner on, off, or both ? If this is a problem with the air cleaner on, you may not have the proper air cleaner for the carb...it may be interfering with linkage or other mechanisms ...
sdtsdt is offline
post #8 of 10 (permalink) Old May 10th, 04, 02:13 AM Thread Starter
Angry
Thanks for all the suggestions, I will check them out when I get home tonight and post back.
68_SS is offline
post #9 of 10 (permalink) Old May 12th, 04, 02:46 PM Thread Starter
Well I finally got back to the car tonite and found that it was a linkage problem after all [img]graemlins/clonk.gif[/img]
I took it for a short spin to see what kind of difference it would make going from the 750 Edelbrock to the 670 Holley and was a little surprised. I expected better throttle response, but actually it seems a bit more sluggish.
I need to change out the secondary spring to make them open a little sooner and will play with the timing and see what happens.
Thanks for the help.
68_SS is offline
post #10 of 10 (permalink) Old May 14th, 04, 09:24 AM
one more note..
the idle mixture screws will reduce idle if turned in, and will increase idle if turned out.
Keep on truckin' check that timing first, and then have someone fallow you while you test, to see if there is black smoke when you jump on it or not, this will help you determine weather or not you are overfueling (rich) or underfuling (lean)
John...
68ragtop is offline
