Air Cleaner base to fit Demon - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 29th, 04, 02:45 PM Thread Starter
Anyone know which air cleaner base I need to fit the Speed Demon 750 with vacuum advance and electric choke?
This is so much fun I can't believe it's legal.
69 Camaro- Fastsburn 385 crate, 200-4R
69 Chevelle SS 396 4 Speed
Midlife Cruiser is offline
post #2 of 8 (permalink) Old Mar 29th, 04, 04:32 PM
Matt Jones
Any. Even the 1.5" drop base works from K&N.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 8 (permalink) Old Mar 30th, 04, 11:05 AM Thread Starter
Did you have to modify the base to clear the electric choke rod?
post #4 of 8 (permalink) Old Sep 12th, 05, 09:28 PM
Re: Air Cleaner base to fit Demon
i need to also know the same information about making the base to clear the electric choke rod.
--Branden Hall<br />1968 Chevy Camaro<br />327, 4-speed, 3.42 posi
hall85296 is offline
post #5 of 8 (permalink) Old Sep 15th, 05, 05:47 PM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Yes you do. It has to be notched so the choke rod does not hang. I am not sure if you can use any base, but mine is a swap-meet buy and I just had to notch a small section and bend it out of the way and it works fine
Kinda funny how the first two posts are from users who joined Jan 2002 and the next two post are from users who joined in Oct 2003
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #6 of 8 (permalink) Old Sep 17th, 05, 06:54 PM
Kevin
Hey Midlife,
I am having the same problems..I have a 750 demon with an electric choke. Let me know what you find out and I will let you know what I find. I already bought the X-Stream K&N top, but need to get a base and air filter element.
Kevin
67 Camaro rs/350 HO(est. 401hp)/4L80E/8.5" 10 bolt 3.73
Sixty-Seven rs is offline
post #7 of 8 (permalink) Old Sep 18th, 05, 06:49 AM
I use the stock open element a/c base for the Holley and it fits both my Holley and Demon vacumn and electric chokes. They both will clear stock hoods. I have added the upper section to complete cowl hood. Has to be for a Holley carb,, the QJet will not work.
TC # 349
zdld17 is offline
post #8 of 8 (permalink) Old Sep 21st, 05, 02:57 PM
Most standard air cleaner bases can be modified to clear the choke linkage. Otherwise you can get a complete air cleaner assembly from Barry Grant that will clear the linkage.
http://www.barrygrant.com/rush/default.aspx?page=122
Technical Support At Barry Grant, Inc.
BG Fuel Systems, Demon carburetors, Nitrous Works, & Rush Filters
Tech @ BG is offline
