T.P.I. conversion. . . . help wanted - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 26th, 03, 10:15 AM Thread Starter
Chris
Hey all,
I have a mild .030 over 350 and am interested in going the T.P.I. route. Currently the car has a Holley 4 bbl. So far, I have learned that I should try to find a system of a 1986 350 car, so that I can keep my heads. If anyone can give me any advice on this swap, I'd appreciate it.
Thanks.
Chris.
crcorc is offline
post #2 of 5 (permalink) Old Mar 26th, 03, 12:11 PM
well there were only like 50 86's with a 350, so i would forget that one, but go to http://www.thirdgen.org and im sure you can find all the info you are looking for.
86 z28 305 tpi 700r4 <br />00 ss ls1 nbm t-56
Marky_24 is offline
post #3 of 5 (permalink) Old Mar 26th, 03, 12:14 PM
Chad
67 Plum's Avatar
You can get the intake set up from a Corvette 1985-1991 the Vette aluminum heads kept the standard intake bolt patern.
67 Plum is offline
post #4 of 5 (permalink) Old Mar 26th, 03, 02:30 PM
I believe my bud purchased an 86 Firebird which had been wrecked that had a TPI 350 in it. I believe he hangs out on the 3rdgen.org site. If you like I'll see if I can get you in touch with him. He is in the process of assembling as a 383 TPI. He had the 86 heads reworked for larger valves, porting, and deeper spring pockets. Just about ready to tackle the ECM.
-dnult
dnult is offline
post #5 of 5 (permalink) Old Mar 26th, 03, 09:59 PM
The EFI forum at www.chevytalk.com was a huge help for me. I went with the Holley system. The guys there can talk you through pretty much anything.
ramcda is offline
