700r slipping - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 3rd, 01, 02:40 PM Thread Starter
I have a '84 chevy s-10 with a 3.4 and 700r4 tranny. I am getting ready to put a 327 in in about a month so i really dont want to have to service my tranny unless necesarry, cause i have to have a differnt one for the other motor. It had been slipping out of OD for about a month or so, "i think the roller clutches were going" But today, it has been ticking when in park. It goes away once you are in drive. But if you get on it too hard it will fly out of 3rd and you have to let off the gas. As soon as you do it goes back in. Will i be able to baby it for another month or so or does this baby need overhauled?
racerboy3v is offline
post #2 of 6 (permalink) Old Jan 3rd, 01, 05:24 PM Thread Starter
Also, i may switch out my auto tranny for a 5 speed. I dont know if anyone knows, but would i have to get a differnt transfer case?
Or would i be better off with a 200r? What is the rap on them? Beter than the 7oo as far as durability? What about cost? And bolt patterns? hookups? Are they hydralic shifts?
post #3 of 6 (permalink) Old Jan 3rd, 01, 07:52 PM
WE4
First of all roller clutch isn't in 4th. second.... I think your converter neck is cracked and or the flexplate. That is the noise or tick you described. Also cracked vein ring in pump is possible. When this occurs it goes low on line pressure hence the slipping.
Hope this helps and 2004r is the way to go. That didn't sound too bias, did it? LOL LOL LOL
Bruce
WE4
Thank You
WE4
Bruce Toelle
Performance Transmissions
"WE GOT THE 2004R PARTS!" www.ptsnctb.com
[email protected]
[This message has been edited by WE4 (edited 01-03-2001).]
WE4 is offline
post #4 of 6 (permalink) Old Jan 4th, 01, 03:48 PM
Double check , But I think the 3.4l is a 2.8l replacement. This has a different mounting flange than the 327 V8 and you will need a different trans anyway.
TTFN
Mat
Mat Klemp is offline
post #5 of 6 (permalink) Old Jan 4th, 01, 04:24 PM Thread Starter
Pretty close Mat. Actually my 3.4 was my own invention. I took a lumina z-34 bottom end and bored out a 2.8 block so the pistons would fit. hen put 2.8 heads a.s a holley 390 4 barrel carb on top. I was hoping to get more umph out of it thean the 2.8 and i did. But after putting on 309.50 Bfg's on it kinda zapped the power out of it. So i decided it would be a good project to put a 327 in it. I am pretty sure it takes a differnt tranny for the v-8 but i wasnt wanting to rebuild mine now and then have to buy another one later for the 327. But, it looks like i'll have to anyway. Such is my luck
post #6 of 6 (permalink) Old Jan 5th, 01, 07:31 PM
Sounds like a fun project. The 327 won't bolt to your old tranny, the bolt pattern on the 2.8 is much narrower. If it's a stick you can get a different bell housing but the input shafts for the V-6's are much smaller than there V-8 counterparts and are prone to breaking under the greater power. An automatic 700-R4 is the way to go anyway. Check out JTR, they make a book for that conversion. They've been doing it for almost twenty years now and have it down to a science. You might want to think about changing out your 7.5 inch rear end also. Its only good for about two burn offs with a posi and 300hp.
Matthew Baker is offline
