Possible starting issue - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 23rd, 04, 08:41 AM Thread Starter
D
When starting my 68, there is a slight pause or delay. Sounds like the battery is under more than normal load or maybe the starter has trouble turning for a half sec or so. I am just guessing here but wanted to get some opinions. Thanks much!
Domano 68 is offline
post #2 of 6 (permalink) Old Sep 23rd, 04, 09:17 AM
Steven
Make sure that battery cables are clean ... do a load test on the battery ... many auto stores will do that for you ... you may just have a weak battery and need to replace it
sdtsdt is offline
post #3 of 6 (permalink) Old Sep 23rd, 04, 10:28 AM
Vintage 68's Avatar
The armature may be dragging due to a worn end plate bearing.
New end plates or replacemnt bearings are readily available. You could try turning the end plate 180deg to see if the drag changes - it won't fix all the problems, but may tell you if your on the right track, this can be done without removing the starter.
Dirty/worn contact plate or contacts in the solenoid can cause hard start issues also.
I would also recommend you have the starter current draw tested to see if it's in spec.
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 6 (permalink) Old Sep 24th, 04, 04:51 AM
You could just have a touch more initial timing than you should. Is the problem worse or better when the motor is hot?
post #5 of 6 (permalink) Old Sep 24th, 04, 06:26 AM
You must make sure the cables, inside and outside, and their connections are clean and of the proper wire gauge to handle the load.
If the battery is over a couple years old, it sometimes takes a second for itself to start and ramp-up the chemical reaction to handle the current load requested.
post #6 of 6 (permalink) Old Sep 24th, 04, 09:58 AM Thread Starter
D
Jim,
Now that you mention, it seems to occur when the car is warm or been recently driven.
