GM crate engine & fuel injection - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 9th, 01, 01:34 PM Thread Starter
I'm looking into buying a third gen. and was wondering if I could buy a GM engine such as the H.O. 350 and scrap enough parts off the old car to set it up w/the stock fuel injection. Would fuel injecion from a 305 work or would it have to be from a 350? Is any of this possible or am I just dreaming?
Jesse210 is offline
post #2 of 7 (permalink) Old Mar 9th, 01, 03:53 PM
GM makes a complete kit to replace the low Hp engines in the third gen. The motor is a ZZ4 (345hp) but the kit is only available for the carburetor model third gens. The latest Chevy High Perfromance Magazine has an article on this replacement.
1st & 2nd GENGuy is offline
post #3 of 7 (permalink) Old Mar 9th, 01, 05:57 PM
If you used the HO 350/330horsepower, the vortec heads used on that engine wouldn't jive with your 305 fuel injection manifold.
boodlefoof is offline
post #4 of 7 (permalink) Old Mar 9th, 01, 06:24 PM
if it is a TBI unit yes you could use it. GM just came out with a TBI vortec manifold. if it is TPI you are SOL, not gona work. till they make a manifold for the vortec head's.
to go from a 305 to a 350 you need to normaly get bigger injector's and up the fuel presure on the TBI. the TPI need's a new chip and maybe injector's.
what type of FI do you have? also the vortec head's do not have a EGR out let. you need to plumb one in from the header's or exaust manifold's.
ilbl8 is offline
post #5 of 7 (permalink) Old Mar 9th, 01, 06:42 PM Thread Starter
So if I'm going to be considering swapping from a 305 to 350 when I pick up a third gen, should I look for a carbureted or injected model? How do I know the difference between TBI and TPI? Anybody wanna buy my 86 camaro w/22k original miles? drawback is the v6,$4499 obb. Thanks a lot for the help so far guys.
Jesse210 is offline
post #6 of 7 (permalink) Old Mar 9th, 01, 08:27 PM
TBI look's like a carb kinda, it has 2 fuel injector's in the midle. TPI well it look's hi-tech . good luck!!!
ilbl8 is offline
post #7 of 7 (permalink) Old Mar 11th, 01, 08:00 AM
Look for a 3rd gen with a 350 already in it. If you can't find one don't wanna mess around then get the 305 TPI (1989 had a better computer, don't get an '85 though) and buy a 383 crate engine, port/polish the plenium on the TPI, buy an aftermarket base, get a 58mm throttle body and probly 24-28lb injectors, have one of the 3rd gen guys burn a custom chip, and tap it for n2o nossles on each port...and yes I've thought about it before.
If you do go with a HO 350 or a 383 go with a 90-92 TPI. It has speed density and not an MAF that can only run about 650cfm after modification.
67stock is offline
