Steam holes in heads but not in block - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 6th, 05, 07:05 PM Thread Starter
My Canfield heads came delivered with steam holes already drilled. My big bore Bow-Tie Sportsman block does not have steam holes and I was not planning to drill them. Do I need to plug the steam holes in the heads or will the gasket without steam holes seal them up?
Also, when looking in the block's water jacket, I can see where the water jacket ends between the siamesed cylinders. If I did drill the steam holes, they would be behind the water jacket. What would I be drilling into? Is it solid casting? If so, what is the point with the steam holes?
Thanks. -Neil
Neil B is offline
post #2 of 3 (permalink) Old Jan 6th, 05, 07:29 PM
Sean
unless you plan on idling around town daily for hours on end, don't worry about the steam holes. they were there for cars that spent thier life idling, (i've actually heard under 1500rpm continuous) and never had a good steady flow of coolant moving around the block, esp. at the siamesed area. thus creating hot spots and steam pockets.
none of my half dozen or so buddys or myself with 406's have ever drilled them, most of our cars are street strip cruisers, but we have all driven them extensively on the street as well. mine runs 180 all day, any weather, with a 3 core copper brass radiator.
as for your steam hole issue, just run them and the gasket will take car of the rest. mines the same way, only holes in the block. they will seal fine.
of course, as always just my opinion from my experiences.
good luck with it [img]graemlins/beers.gif[/img]
Sean
Franklin D. Roosevelt
68rs406 is offline
post #3 of 3 (permalink) Old Jan 7th, 05, 10:15 AM
Just ordered new Protoplines (200's w/ 72cc)and shop said no holes needed.So I'm gonna try them without the hole and see what happens.Most say 50/50 shot.
68 Camaro~LSx ~all motor
