502ho in a 69 camaro questions - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 1st, 04, 03:55 PM Thread Starter
Hello everyone, does anyone have experience with the Gen 6 bbc engines in older GM chassis? I want to install the 502 ho in place of the 454 that's in it now but heard the oil pan won't clear the crossmember. Then I saw somewhere that it will fit but be too low. Any help would be greatly appreciated.
Tubbed69 is offline
post #2 of 5 (permalink) Old Oct 1st, 04, 04:35 PM
prostreet69camaro's Avatar
I have a 502 blower motor in my camaro. The 502 oil pan will not work. I put a stefs pan on mine but it is very close to the crossmember. I also have a 502 ramjet that I am putting in another 69 and it has a milidon pan. It fit with no problems. Buy the milidon pan and the correct oil pump pickup. I also used the Hooker super comp headers 2-1/8". I had to ding the driver side by the power steering pump. The passenger fit right in but I had to cut a 5/8" socket to fit the sparkplug on # 4 cylinder. After market motor mounts with moroso steel mounts fit with no problems.
prostreet69camaro is offline
post #3 of 5 (permalink) Old Jul 1st, 05, 04:32 PM
Re: 502ho in a 69 camaro questions
Jon, Did you put a 502 Ramjet under a standard cowl hood?
tobin67 is offline
post #4 of 5 (permalink) Old Jul 1st, 05, 07:10 PM
Hi Jon
I had to change the oil pan to fit in my 69. If you do a search under my name
Joe 69 there is a lot of info that may help you out regarding the 502 (what will fit not fit etc.) If you have any specific questions just let me know.
<BR>
Joe 69 is offline
post #5 of 5 (permalink) Old Jul 1st, 05, 07:50 PM
What tranny did you use?
Do you have a pic?
tobin67 is offline
