zz572 - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 19th, 04, 04:08 AM Thread Starter
Anyone have any experience putting a ZZ572 in a 69 Camaro. Before I buy I want to see if headers will fit and the tall deck/intake will clear the cowl hood Thanks Don
muscleman is offline
post #2 of 5 (permalink) Old Dec 19th, 04, 06:17 AM
Jody
camcojb's Avatar
You will likely need as aftermarket cowl hood to get any kind of a decent air cleaner on there. The stock steel cowl is tight with a standard deck height. Companies like Lemons Headers make headers for the tall decks and raised exhaust ports; standard big block headers will likely not fit, they wouldn't work on mine with a standard deck and raised exhaust ports.
Jody
camcojb is offline
post #3 of 5 (permalink) Old Dec 20th, 04, 11:19 AM
JohnZ's Avatar
The top of the 572 tall-deck block at the front and rear where the intake sits is 1/4" higher than the standard-deck block. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #4 of 5 (permalink) Old Dec 20th, 04, 07:04 PM
Hey Don - I've got a 454 in my 69 with a performer RPM Airgap intake, 1" carb spacer, holly 850 and a stock repro cowl hood - I'm using a dropped base with 14x3 K&N, and the K&N XStream lid - it's tight but fits with the aircleaner up in the cowl.... you clould probably nix the 1" space with the 572....
Nick
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #5 of 5 (permalink) Old Dec 20th, 04, 07:19 PM
Jody
camcojb's Avatar
Nick,
Have you ever run that car with a taller filter and no hood? You might be surprised. Even with that top a 14X3" dropbase is too restrictive for a healthy big block. I had a car pick up .7 in the 1/4 with a 5" filter over a 3" drop base.
Jody
camcojb is offline
