How to tell if heads are correct - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 29th, 04, 05:31 PM Thread Starter
Chris
I have a 350 small block in my car, I ran the #'s off the block and it says it is a 300 hp engine. How can I tell if the heads are the correct heads for this engine?
ck 2 is offline
post #2 of 6 (permalink) Old Dec 29th, 04, 06:07 PM
Chad
67 Plum's Avatar
Get the casting #s and date codes off the heads.They are under the valve covers between the valve springs.Last three digits of the casting # should be 041 for a 300hp 350 if its a 69.
67 Plum is offline
post #3 of 6 (permalink) Old Dec 29th, 04, 06:07 PM
Brandon
Go to www.mortec.com look up the casting #'s. Then look for the date code and see if they are within a couple weeks of the car build date.
Nantooch is offline
post #4 of 6 (permalink) Old Dec 30th, 04, 05:05 AM Thread Starter
Chris
Thanks, I'll check them out.My car is a 69.
ck 2 is offline
post #5 of 6 (permalink) Old Dec 30th, 04, 12:51 PM Thread Starter
Chris
3947041 is the # on my heads, so I guess they're right.
ck 2 is offline
post #6 of 6 (permalink) Old Dec 30th, 04, 05:59 PM
Chad
67 Plum's Avatar
That is the right casting #s.
67 Plum is offline
