seriously stuck pistons......... - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 16th, 04, 12:36 PM Thread Starter
Virgil
Friend just brought a 68 396 short block to me, to see if I can help him remove the pistons. Problem is, it has sat outside for years with no heads, or oilpan. He did manage to remove the crank without damaging it (I don't see how, but he did!)
What is the best way to get the pistons out? He has been soaking them for days with ATF, Pen. oil, etc. He is not worried about the rods, as he said 2 caps were missing, so he will get a complete new set.
Should I just try to drive them out by wacking on the rods? Heat? Any input is appreciated.
He would just replace it, but it is numbers matching to the car he just got, so he wants to try and save it.
Or should I just get a new friend!!! JK
Thanks,
Virgil
vr1967 is offline
post #2 of 9 (permalink) Old Apr 16th, 04, 12:52 PM
I'd remove as much rust and scale as you can with sandpaper or steel wool and penetrating oil. Then rinse out the cylinders good with spray cleaner (gunk works good) to remove any grit. Then put a wooden hammer handle or 2 X 2 against the back side of the piston and whack it. Chances are that rust has already pitted the cylinders to the point that it will take 0.040" to 0.060" to clean them up anyway so I wouldn't worry too much about being gentle.
dnult is offline
post #3 of 9 (permalink) Old Apr 16th, 04, 01:48 PM
Chad
67 Plum's Avatar
I have found in the past that you can drive the piston down in the bore easier than up. If you can get it to go down you can sand or hone the cylinder to get them out.
67 Plum is offline
post #4 of 9 (permalink) Old Apr 16th, 04, 03:15 PM
My current 388 was exactly this way when I got the engine from the salvage yard...and it had heads on it. It was a standard bore but just BARELY cleaned up at .060 over. I had to literally beat the pistons out of it with a piece of steel pipe and a small sledge hammer. I shattered 3 of the pistons getting them out...they was that bad.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #5 of 9 (permalink) Old Apr 16th, 04, 05:29 PM
I wonder what would happen if you greased the bores up real good with a stiff old-fashioned stringy wheel bearing grease and then filled the bores up with muratic acid and let it eat on the aluminum piston tops??
Won't a Hot tank that has Cresol in it eat aluminum cam bearings out?? Maybe it would do the same thing to your pistons??
Or PB-Blaster penetrating oil??
pdq67
post #6 of 9 (permalink) Old Apr 17th, 04, 04:35 AM
Jon
Lye eats aluminum and doesn't eat iron (much). All you need is a big tank to dip the engine in and lots of lye. You can buy lye at most farm supply stores. Say goodby to the pistons.
Jon N
dyno jonn is offline
post #7 of 9 (permalink) Old Apr 17th, 04, 07:02 AM
Royce
Personally I would break the pistons and take them out in pieces. Much like Travis did, if they come out whole then that's great if not they will break. If they are cast it will be easy to break them.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #8 of 9 (permalink) Old Apr 17th, 04, 05:37 PM Thread Starter
Virgil
Thanks for all the help. Have managed to get 4 out so far. (Ran out of time, as I had to work late today)
1/2 way there. Maybe I can do it without messing up the block.
Thanks, again,
Virgil
vr1967 is offline
post #9 of 9 (permalink) Old Apr 19th, 04, 10:01 AM Thread Starter
Virgil
Have all the pistons out. Block is std bore, so it should clean up nicely.
Will send it to the machine shop to have it tanked and bolt holes checked before any other work is done.
Thanks again for all the help.
Virgil
vr1967 is offline
