70's vs. 80's 4-bolts - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 6th, 05, 07:27 AM Thread Starter
Guess
HwyStarJoe's Avatar
I know that the 70's SBC 4-bolts aren't really any different than their 2-bolt twins as far as strength of the bottom end, but did things improve in the 80's?
Is an '87 4-bolt 350 any stronger than it's 2-bolt version? And were they also mostly seen in trucks rather than cars?
HwyStarJoe is offline
post #2 of 3 (permalink) Old Jan 6th, 05, 09:22 AM
Hencho en Mexico <---not these blocks.
68 Camaro~LSx ~all motor
post #3 of 3 (permalink) Old Jan 7th, 05, 03:51 AM
Eric
The castings started getting lighter in the mid to late 70's and the castings more porus when they started making them in Mexico.
As far as I'm concerned from about 75 through the mid-80's were the "dark years" and I would avoid these castings if possible. I think the late 80's and 90's castings get a little better due to improved QC but I wouldn't hang my hat on that when building a serious high perf engine.
My next engine will be based on an aftermarket block for sure. These blocks are only about $1000 more than the cost of buying an old core and getting it machined.
Eric68 is offline
