No coolant pressure? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 27th, 04, 07:21 PM Thread Starter
My 327 doesn't seem to run hot. But, the radiator hozes sometimes don't have any pressure - even after running for quite a while, in warm weather. Engine runs fine. No leaks. Anyone think there is a problem brewing? I'd like to catch it early if so....
1968, M20 PDB 12posi-3.73 400SB (KB125 5.7"r AFR195 CS286H 750cfm-mech-annular_boost 10.2CR AirGap 6AL)
rogue68 is offline
post #2 of 3 (permalink) Old Apr 27th, 04, 08:18 PM
Matt Jones
Don't turn a simple thing into a complicated subject.
If the engine runs good, doesn't leak, doesn't overheat, and doesn't boil-over, then you're OK. Get out and enjoy the car.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 3 (permalink) Old Apr 28th, 04, 02:34 AM
Usually that is a sign of a bad radiator cap provided you don't have any leaks. Either that or you don't have a termostat installed and the cooling system never gets hot enough to build up pressure.
dnult is offline
