Won't start after running out of gas. - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 23rd, 01, 04:08 AM Thread Starter
This is not my vehicle, but I may be able to get it really cheap. This is an 89 GMC Z-71 pickup. 350/5 spd. The truck ran out of gas and now they can't get it started. I don't know the details of what they tried, but knowing this guy, he probably just poured gas in and turned it over. Any ideas on if there is somekind of reset switch or bleeding procedure for this motor? I believe the 89's were fuel injected. They have bought a new truck and this one has only been sitting like this for about a week. I wouldn't mind having a 4x4 cheap if I had a starting point to look for the no start problem. It ran fine up until it was ran out of fuel. Thanks for the info.
fade941 is offline
post #2 of 7 (permalink) Old Jul 23rd, 01, 04:36 AM
Turn the key to the run position and see if you can hear the fuel pump. I've seen where someone runs out of gas and burns up the fuel pump which should be located in the fuel tank. I don't think there is a reset for running out of gas.
68.camaro is offline
post #3 of 7 (permalink) Old Jul 23rd, 01, 05:18 AM Thread Starter
Thanks for the fast response. Some of the newer cars have a reset. I had a 97 auto from another maker, that had a reset button that had to be activated to restart the car. This had to do with the warranty. If you ran the car out of fuel, it voided parts of the warranty, so you had to have the dealer or a dealer rep reset it for you so it could be recorded.
As far as the fuel pump in the tank, is it attached to the sending unit as one piece? Or can the pump be replaced seperately?
fade941 is offline
post #4 of 7 (permalink) Old Jul 23rd, 01, 05:57 AM
Royce
I laso agree that it could very well be the fuel pump. It is common for them to fail after the tank has been run very low or empty and then filled. I was told it has to do with the pump getting warm and then the cool gas get put in and it causes them to fail. I also heard that this is the most common time for an electric fuel pump to fail. Beware some of the newer fuel pumps are very quiet and you might not be able to hear it even if it is running. I would turn on the key or have someone else do it while I crawled under the truck for a listen. You will not have to replace the whole tank, just the pump. If you really know this guy and trust that what he is telling you is true (on how the problem started). If the price is right, buy it and you can fix it and sell it if you don't want it.
Royce
70 Camaro 383ci
69 Camaro 385ci
91 Camaro RS V8 (305 TBI)
Link to my 70
http://profiles.yahoo.com/camaroman7d
camaroman7d is offline
post #5 of 7 (permalink) Old Jul 23rd, 01, 06:18 AM Thread Starter
I am still waiting to hear what the price is. I did find out that they have already determined it is the fuel pump. The 4x4 part is not working currently due to a bearing problem, or so I'm told. Kelly Blue Book is $4300 in fair condition. I was hoping to get it for around $2-$2500
fade941 is offline
post #6 of 7 (permalink) Old Jul 23rd, 01, 12:53 PM
It could be that running the last quart of fuel (or gunch) of a 12 year old fuel tank clogged the filter, mesh tank filter, or lines. See where/if you have flow from tank to engine. Good luck!
Sleepy-69 is offline
post #7 of 7 (permalink) Old Jul 23rd, 01, 01:49 PM Thread Starter
Not going to touch it until I have it. I would like to get it to pull my 68 to and from the track. The 4x4 would come in handy when I go to CO to hunt. And, I have a wholesale deal with a 4x4/Offroad supplier and I can get way cool stuff cheap.
fade941 is offline
