Computer controlled HEI? - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 28th, 04, 08:21 PM Thread Starter
I've been looking around for a computer controlled HEI distributor. I believe they came in '85-'91 TPI Corvettes and come camaros.
I've looked and I'm not sure what I need. Nothing I've found seems to have the connector that connects to the computer. Is this even something I can buy new? I've found ones with the module included but that isn't the connector to the computer is it?
Please help.
Dan-69rallysport is offline
post #2 of 2 (permalink) Old Apr 28th, 04, 09:45 PM
they should be easy to find- pretty much any GM car made after 82 or so had them. there are 4 versions, tho- a big cap one that has the same cap as a regular HEI, and a small cap setup with an external coil. neither of these will have a vacuum advance can on it. some mid 80's trucks had a computer controlled HEI that has a vacuum advance can on it, as well. the 90-93 Caprices with the TBI 350 or 305 have their own distributor, which is a small body external coil setup, but only fits the bigger hole in the B body TBI intake that allows you to actually take the thing out with the engine in the car.
you don't plan sincerity.
novaderrik is offline
