manual trany for a sb400 - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 26th, 01, 10:22 AM Thread Starter
hi all im new here and have a question? i want to put a t5 manual trany behind a chevy sb 400 question is .is the flyweel extunaly balanced on a 400 or can i use the one from a 350? thx for yor time
Wildside is offline
post #2 of 6 (permalink) Old Feb 26th, 01, 10:44 AM
you will need the proper (externally) balanced flywheel for the 400.a 350 is internally balanced and the flywheel will not work.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #3 of 6 (permalink) Old Feb 26th, 01, 12:21 PM
if u do use the 350 fly wheel your motor will for sure fall apart make sure to also get the right harmonic balancer good luck
camaro79tx is offline
post #4 of 6 (permalink) Old Feb 27th, 01, 04:44 PM
Wildside,
GO TO EBAY RIGHT NOW and type in a search for "400 block." I just did, checking prices on a bare block, and found for $26 I think the adapter to use any 263-350 sbc flywheel.
I think it ends in a day or so.
Here's the link: http://cgi.ebay.com/ebaymotors/aw-cg...item=562689463
-Chuck
78 Camaro Z28 clone - 350hp/460ft/lbs 400 small block / TH350, full poly suspension, 2" lowered, 1-1/4" & 1-1/8" sway bars
[This message has been edited by Chuck78 (edited 02-27-2001).]
Chuck78 is offline
post #5 of 6 (permalink) Old Feb 28th, 01, 05:35 PM
Don't forget to check the block to make sure the clutch linkage stud boss is drilled and tapped. Many 400's were not and it's a pain to do in the car. The boss is above the oil filter mount.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #6 of 6 (permalink) Old Mar 1st, 01, 06:30 AM Thread Starter
thanx for all the info guys it was all needed i found ebay and contacted seller
Wildside is offline
