low oil pressure, but plenty of oil... - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 31st, 04, 09:00 AM Thread Starter
JTM
not sure if its just my guage, but it hangs @ around 20lbs of pressure. and drops slowly as the engine warms up. any ideas?
JTM is offline
post #2 of 10 (permalink) Old Mar 31st, 04, 09:10 AM
Vintage 68's Avatar
"Drops slowly" to what
If you are relying on the electric gauge I would install a mechanical right on the engine and see if it reads the same or different.
Hard to say what it could be at this stage.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 10 (permalink) Old Mar 31st, 04, 10:35 AM
Eric
I wouldn't sweat it if you are talking about pressure at idle until you start getting down below 10-15 lbs.
The old thumb rule of 10 psi per 1000 RPM is a good reference point. As long as pressure comes back up with the revs you should be fine.
Eric68 is offline
post #4 of 10 (permalink) Old Mar 31st, 04, 12:19 PM Thread Starter
JTM
it goes up with revs, but i dont think it is even above 10psi @ any time when the engine is warm. also, on my pontiac 350 there is a plug in the head on the right side in tyhe front, it has 2 prongs.. i think its a temp sensor, and my temp guage doesnt work.. am i right in assuming whatit is? and how do i hook it back up?
JTM is offline
post #5 of 10 (permalink) Old Mar 31st, 04, 12:50 PM
Bob
If it's under 10 lbs. at idle, you have issues to deal with.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #6 of 10 (permalink) Old Mar 31st, 04, 07:28 PM
David Pozzi
davidpozzi's Avatar
If it goes completely out of pressure, the hyd lifters will start to clatter, that is a sure sign of oil pressure loss.
Put a mechanical gage on it and see what it is. I know on BB chevys, the oil pump pickup can fall out and the oil pressure drops!
davidpozzi is offline
post #7 of 10 (permalink) Old Mar 31st, 04, 07:57 PM
My old Camaro used to run around 10 lbs and go up and down with engine speed. Tore it down and found that the oil pump bolts were not tight and it was leaking back into the pan.
sudo1a67ss350 is offline
post #8 of 10 (permalink) Old Apr 1st, 04, 05:07 AM Thread Starter
JTM
even if my valaves or lifters were making noise, i coudltn hear them.. i also have an exhuast leak.. i think its a gasket @ the manifold.. is it possible i have a hole in my head cuasing a leak as well? i put my finger down near the noise and i feel the hot air... it sounds alot like i am missing a spark plug, but i assure you they r all there.. and tight. thanks [img]smile.gif[/img]
JTM is offline
post #9 of 10 (permalink) Old Apr 1st, 04, 05:08 AM Thread Starter
JTM
can any of you suggest a good repair manual? ive always steered clear of haynes and chiltons, in favor of the more detailed manuals, but maybe in this case those r the right books?
JTM is offline
post #10 of 10 (permalink) Old Apr 1st, 04, 05:47 AM
Get a Helms Manual for your car. That is what the technicians use.
69X11SS is offline
