valves noise - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 10th, 04, 11:55 AM Thread Starter
I got done breaking in my rebuild engine last weekend.The break in went smothly.Next day ican heard valves clicking on the right side.I adjusted valves today with 1/4 turn preload and noise is still ther.Shoud i give it 1/2 turn preload?I do have Edelcrock rpm heads and cam.Does engine have to be cold or hot? Thanks
Jarda is offline
post #2 of 10 (permalink) Old Apr 10th, 04, 06:51 PM
do you have roller rockers?
<a href="http://atlas.walagata.com/w/artfuldodgerv2/AAAA0017.JPG" target="_blank">68 RS</a> : 383, performer RPM heads, Victor Jr. Intake, Holley 780 DP, Crower 224HR232, 700R4 trans, 4.56:1 10 bolt. - driven every day
YouthTronix is offline
post #3 of 10 (permalink) Old Apr 11th, 04, 06:20 AM Thread Starter
Yes
Jarda is offline
post #4 of 10 (permalink) Old Apr 11th, 04, 09:28 AM
sounds like you probably need to adjust the roller rockers then. If this is the case. You will take off the valve cover, and make sure you can tell which rocker arms need adjusting. Then you will turn on the motor. And then slowly tighten the rocker arm down (without putting any pressure down on it) And tighten it very slowly, just until you hear no more clicking, and then give it one more half turn. Also be prepared since if you wait long enough, oil will begin to poor out. If you do it on a cold engine you will have longer until oil starts coming out.
post #5 of 10 (permalink) Old Apr 15th, 04, 10:23 PM
jarda;
also see the post entitled "strange noise and setting the valves"by marc
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #6 of 10 (permalink) Old Apr 15th, 04, 10:24 PM
this is a hydraulic lifter engine right???
post #7 of 10 (permalink) Old Apr 15th, 04, 10:29 PM
one more thought(sorry)if you have forged pistons they will slap around a bit until the engine warms up,they sound a lot like lifter noise.still i would follow the instructions in the other post for the easiest rocker arm adjustment.
Eric
post #8 of 10 (permalink) Old Apr 16th, 04, 12:34 PM Thread Starter
Yes, i do have hydraulic lifters and forged pistons.I adjusted valves twice.Noise stop when i disconect vacuum hose to the distributor.
Jarda is offline
post #9 of 10 (permalink) Old Apr 16th, 04, 09:37 PM
is your pcv valve on the right side?
post #10 of 10 (permalink) Old Apr 17th, 04, 01:32 PM Thread Starter
Pcv valve is on the pass side.Driver side have edelbrock breather.I adjusted the timing yesterday and it is better.
Jarda is offline
