Which motor mounts for my 72?? - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 10th, 05, 02:10 PM Thread Starter
I have a 72 camaro factory small block car. I'm putting a big block in it and I'm unsure which mounts to use. I'm using hooker super comp 2 1/8" primary headers. The car come from the factory with the clamshell style mount, which mounts to the engine and the rubber part is on the crossmember. Does anyone know what engine mounts I will need and if I need the old style (rubber on engine) or the new style (rubber on crossmember)?
Strokd66 is offline
post #2 of 2 (permalink) Old Jan 10th, 05, 03:38 PM
Probationer
they came out with the big block motor mount for the 72 clam shell type engine mount I think opg carries them they're about 60 or 70 dollars. I have a 71 and had to order the bbc steel frame stands and rubber mounts.
Jim Mac is offline
