cam selection - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 17th, 04, 03:46 AM Thread Starter
s4h
i have a 66 396 325 hp the cam that was in has no recognizable numbers. what would be a good cam for this motor? street use 4spd 12 bolt 3.08 rears looking for some good hp and a nice lumpy sound also running a pete jackson gear drive , holley 780 and headers. thanks scott [img]graemlins/clonk.gif[/img]
s4h is offline
post #2 of 9 (permalink) Old Dec 17th, 04, 11:03 AM Thread Starter
s4h
anybody?
s4h is offline
post #3 of 9 (permalink) Old Dec 17th, 04, 02:01 PM
Smile
A CC 280 Magnum will put you up about 380 or so hp, but I don't know how it will pull your 3.08 gears b/c they are sized such that a CC 268HE or 270 Magnum would work better, but not have that "Sound" you want...
Whatever you do, I strongly suggest installing valve springs recommended for the cam b/c the stock 325hp/396 springs are only good for NO MORE then .500" AND are known to BREAK and cause all sorts a BAD things!!! If you have stock stuff, that is????
If it was my motor, I would install a good old CC 270S solid cam in it with good springs and GO...
I over cammed my 406 SB with an M-20, 3.31-posi and 26.5" tall tires and just let my clutch take the beating so know how road gears kinda wear on you after a while....... BUT it sure had that "Sound"!!!
pdq67
post #4 of 9 (permalink) Old Dec 17th, 04, 10:13 PM
Agreed with pdq67 - CC 280 Magnum would be the way to go - Your stock springs or a new set will work fine since the lift is only about .500-.520... But check them out, You'll need at least 95lbs spring pressue on the seat...A cam on a 110-112 lobe center will help give you that rough idle....had the same cam in my 454 - ran good- just not enough - went to the CC 292 Magnum.....
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #5 of 9 (permalink) Old Dec 18th, 04, 01:56 AM Thread Starter
s4h
thanks guys. if i change the springs think i could go the cc292 or is that going to be overkill?
s4h is offline
post #6 of 9 (permalink) Old Dec 18th, 04, 01:59 AM Thread Starter
s4h
eventuly i want to put 3.73 gears.
CUSTOM FABRICATIONS
& POWDER COATING
s4h is offline
post #7 of 9 (permalink) Old Dec 18th, 04, 05:37 AM
Smile
Imho, not with the 3.73 gears.
The hy-cam I have in my 406 SB is a Melling 292/230, 109/107, .480" lift and for my setup it is too big until she is above 2500rpm, and then hold on!!
pdq67
post #8 of 9 (permalink) Old Dec 18th, 04, 12:50 PM Thread Starter
s4h
thanks guys also any sugestions on a good clutch to use ? thanks again and a merry christmas to all.
s4h is offline
post #9 of 9 (permalink) Old Dec 19th, 04, 05:48 PM
I'm using a RAM 11" setup. Diaphram style pressure plate resprung to 3200lbs and a RAM six fingered brass clutch disc - Er, no slippage - more worried about breaking the stock drive shaft, universals, or axles......
nick V is offline
