pulley ? - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 14th, 04, 08:18 PM Thread Starter
Big daddy
Just finishing 383,taking out 327.My question is,by going to a 8in.bal will all pulleys lineup?If not,what do guy suggest.I would like to leave alt on driver side.
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 7 (permalink) Old Sep 15th, 04, 04:26 AM
Brandon
Pullys will still line up. There will just be a small amount of clearence between the fan pully and the crank pully.. Everything else will be the same unless you went with a long water pump.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 7 (permalink) Old Sep 15th, 04, 06:29 AM
If you have power steering, that bracket won't go back on with the 8"
post #4 of 7 (permalink) Old Sep 15th, 04, 04:18 PM
Brandon
Jim- It wont? better go pull mine off then. [img]graemlins/clonk.gif[/img]
Nantooch is offline
post #5 of 7 (permalink) Old Sep 15th, 04, 05:23 PM Thread Starter
Big daddy
no,I don't have power steering,just hoping the pulley lineup with the 8 in.bal.yhe 327 has a 6in.I guees I just need pullys for a 350.
carhodge is offline
post #6 of 7 (permalink) Old Sep 17th, 04, 05:39 PM
If you do go with an 8 inch balancer try not to get the one that times at the 12 o'clock position. If you do use that one you can order a balancer cover that bolts on and has 0 at the common 2 o'clock position and degree marks for advancing. I got mine from Summit and they are reasonable in price.
deerhunter is offline
post #7 of 7 (permalink) Old Sep 20th, 04, 11:48 AM
Nantooch,
Yes, if you have an 8" balancer on a 327 with the motor's original power steering brackets, well then it does not fit and you better get it off quick before you hurt something.
Your SS would have come with a 350, which came with an 8" balancer, AND different power steering brackets to clear it. The original 350 stuff is still there.
[ 09-20-2004, 06:34 PM: Message edited by: JimM ]
