A&N fittings - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 29th, 04, 01:36 PM Thread Starter
Wayne
I just bought a braided line kit the runs from the fuel pump to my carb. I tried sliding the line into the correct fitting, but cant. Am I supposed to cut the braided line off so it will fit? I tried taping the line, but it is just to tight.
-Wayne
WaynesWorld is offline
post #2 of 4 (permalink) Old Sep 29th, 04, 03:04 PM
the fitting that goes on the braded line screws on.i put a dap of oil on the fitting that screws in the fitting you put on the braded line,its tight.must make sure the braded line is cut stright and no burrs
jaw2 is offline
post #3 of 4 (permalink) Old Sep 29th, 04, 04:24 PM Thread Starter
Wayne
Thanks! [img]smile.gif[/img] Worked like a charm.
I ended up using a vise to hold the socket and muscling the hose ends in.
-Wayne
post #4 of 4 (permalink) Old Sep 30th, 04, 12:17 PM
If you are using braided teflon with compression type fittings.
1. Tape the line with strapping tape and mark to cut.
2. Use a fine toothed hack saw to cut the line. Do not use anytool that crushes the line to cut it.
3. use needle nose plyers to flar out the end of the tubing slightly - slightly. If you don't, the tubing won't seat in the ferrel properly.
4. Install the ferrel. Make sure the tubing seats fully. Gently persuade the tubing into position if necessary with a blunt object, smooth end of a drill bit, etc.
5. Install the threaded compression sleeve on the tubing.
6. Remove what is left of the tape.
7. Put a drop of oil on the fitting nipple.
8. Force the tubing over the nipple.
9. Put a drop of oil on the threads.
10. Install the compression sleave and tighten until the correct gap is obtained.
11. You may have to repeat this process a time or two to get the fitting oriented correctly (for angled fittings only). The tubing will want to turn when you tighten the cap.
dnult is offline
