Big Block info - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 24th, 03, 08:19 AM Thread Starter
I am looking to find a donor 454 to use in my Camaro. Does anyone have a list of vehicles I should be looking for? Years, casting numbers, issues.
Thanks in advance.
rasp67 is offline
post #2 of 4 (permalink) Old Jul 24th, 03, 09:07 AM
Vintage 68's Avatar
Try doing a search on here for 'locating or where to buy Big Blocks' or just 'Big Blocks' as this topic has been discussed before.
Here is a listing of Chevy Big Block Numbers to help you indentify what you find -
http://www.mortec.com/bbc.htm
Good luck and post back if you need more info.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 4 (permalink) Old Jul 24th, 03, 11:29 AM
Nick
Rarerat's Avatar
454 engines are very easy to come by. If I were looking for 1 i would just check the newspaper for a mid 70's 1 ton truck. these trucks can usually be bought for around 5-800 dollars and if you are lucky it will come with a short tailshaft Turbo 400 trans as well. You can yank the motor and trans and mabey resell the truck for 2 or 300 bucks and then your only out a few hundred for your motor and trans.
I hope this helps,
Nick
Rarerat is online now
post #4 of 4 (permalink) Old Jul 24th, 03, 05:00 PM
Smile
Ditto on the older P/U's b/c mine is a C/K-20/30 '74/'75 motor!!
It was just a good core with a bad crank, but had the good -781 large oval port, open chambered heads on it. Gave $300 for it back in '95...
I was going to make a 475 incher but the dreaded "more power, Scotty" bug bit me so about all I used to make my 496 was just the good block and the good truck rods!!!
pdq67
