87 - 89 tpi 350 and T5 swap into 67 coupe - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 7th, 04, 11:29 AM Thread Starter
[img]graemlins/waving.gif[/img] Hello all,
I am trying to plan a late model engine and tranny swap into my 67 coupe. I would like to use an 87, 88, or 89 TPI engine and T5 tranny. Has anyone done this or know of a site (or contact info) of someone that has? I'm looking for possible issues with interchange- like drive shaft length, crossmember, etc. I currently have a 350/t350 combo in the car (I DO have the pedals for a manual setup in the car already.) I plan to get the new engine and tranny from a donor car.
Thanks,
inSANe DIEGO is offline
post #2 of 2 (permalink) Old Oct 7th, 04, 02:22 PM
first off welcome to the site.this has definatley been done before.you can look through the archives by using the search button on the top of the page.i did basically what u want except i used a t56 6speed.my tpi setup is controlled by accel dfi.i had a custom drive shaft made.and had to play with the crossmember.you also may want to check out ths site its all 3rd gen camaros,if will help u with all the tpi stuff.good luck....
http://www.thirdgen.org/techbb2/index.php?s=
emtcee1973 is offline
