396 Build - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 15th, 04, 02:22 PM Thread Starter
Hi
Right now my car has a 396, rebuilt to stock 350 horse specs (10.5:1 CR?). I'm looking to install new heads and a cam for a winter project. My question is, what heads and cam should I be looking at? I'm thinking 9.5:1 CR range, beause right now I get a slight knock when I really lay on it. So, what heads and cam, and what kind of power can I expect from it? Right now the motor's only "go fast parts" are headers, Holley 750 and Edelbrock RPM Performer Intake. Oh, and I don't mind a relatively large cam.
I'd like to see 450+ hp/tq if possible.
Thanks, and sorry for the long post
Chase Niblett
1968 SS396 Coupe<br />396, 4-Speed, 12 Bolt 3.55 Posi
ChaseN is offline
post #2 of 4 (permalink) Old Oct 15th, 04, 03:42 PM
You really don't have 10 1/2 to 1 compression now. I wouldn't change your heads they are good ones for a 396. A cam change will help you in both respects more power and less detonation problems.
oger is offline
post #3 of 4 (permalink) Old Oct 15th, 04, 05:31 PM
No more then a good old CC 282S Magnum solid cam will put you at 445hp just like you are with open headers per D2K..
pdq67
PS., and I bet that you should be right at 10 to 1 CR. even though they are rated at 10.25..
post #4 of 4 (permalink) Old Oct 17th, 04, 08:18 AM Thread Starter
Wow, thats all I would have to do? Thanks, this site is an amazing source of info.
Chase Niblett
ChaseN is offline
