Which March PS Bracket/Pulley - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 5th, 03, 04:36 PM Thread Starter
I want to put a polished aluminum or chrome power steering pump bracket and pulley on my 69 camaro but I am not sure which bracket and pulley I need. Can someone tell me if Part # 20160 from March is the correct bracket for the pump below? Also does anyone have a part # for a pulley? Thanks for the help.
350, TKO 5-speed, Moser 12 bolt - 3.73, not as many parts in boxes as before...
pwoolford is offline
post #2 of 10 (permalink) Old Apr 5th, 03, 11:16 PM
why not just get the brackets you have chromed? it would be all shiny, and be GM factory reliable. cost would also be about the same as aftermarket stuff.
you don't plan sincerity.
novaderrik is offline
post #3 of 10 (permalink) Old Apr 6th, 03, 08:15 AM
ZZ_430's Avatar
Angry
Yeah, you need the same setup I have on my 70.
March brackets #20160
Summit pulley #SUM-G3975 (V-belt)
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 10 (permalink) Old Apr 7th, 03, 01:14 PM
Den
DenRS's Avatar
Hey zz430 are those all summit pulleys? I would like to run a similiar set up on my 69. Thanks
DenRS is offline
post #5 of 10 (permalink) Old Apr 7th, 03, 05:26 PM Thread Starter
novaderrik,
I would get my brackets chromed but I have headers and if my memory is right I don't think my factory brackets ever fit quite right.
ZZ430DropTop67RS,
Thanks for the info. Neither of the diagrams on March's web site looked right so I wanted to be sure. Nice looking setup by the way!
Phil
post #6 of 10 (permalink) Old Apr 7th, 03, 06:45 PM
ZZ_430's Avatar
Yeah, they all came from Summit, along with the March alternator and PS bracket kits.
ZZ_430 is offline
post #7 of 10 (permalink) Old Apr 8th, 03, 05:37 AM
Ray
Don, was there an alien looking over your shoulder when you took that photo? I think I see his reflection in the front of the cylinder head. [img]smile.gif[/img]
Ray
68 SS Convertible, Yellow(77 Corvette)
383 w/ EFI on MiniRamII, Trick Flow heads
TKO600 5sp, 3.31 12 bolt Posi
Guildstrand Mod, Baer 13" front brakes, Hydroboost
2016 *ustang front and rear leather seats.
2008 G8 GT
68SSConvt is offline
post #8 of 10 (permalink) Old Apr 8th, 03, 06:55 AM
ZZ_430's Avatar
Wink
That alien appeared after a night of intense partying
[img]graemlins/boring.gif[/img]
ZZ_430 is offline
post #9 of 10 (permalink) Old Apr 8th, 03, 05:45 PM
Den
DenRS's Avatar
Thanks for the info zz430. By the way nice pics. I'm going to use that set up on my car.
DenRS is offline
post #10 of 10 (permalink) Old Apr 10th, 03, 04:29 AM
A friend and I are making those PS brackets with a Bowtie instead of the triangle hole. I'm trying for something a little different
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
Mike's67 is offline
