Best gasket sealer - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 28th, 01, 09:19 AM Thread Starter
Getting ready to put all the stuff back on my engine. New pan, one piece trick flow gasket, water pump, timing cover, Edelbrock RPM intake. Whats the best gasket sealer for the ends of the manifold (in lieu of the cork gaskets)? There are so many choices. I have Edelbrock gasgacinch to use on the intake and water gaskets but I want to also use a little sealer on the ends of the one piece oil pan gasket? Thanks
MStarmer is offline
post #2 of 11 (permalink) Old Jan 28th, 01, 09:35 AM
GM Silicone for the ends of the intake.
1st & 2nd GENGuy is offline
post #3 of 11 (permalink) Old Jan 28th, 01, 10:01 AM
Permatex RTV
"Laissez Le Bon Temp Rouler' Cha!"
Chevytalk Moderator
GMforums Moderator
"Jungle"Jim
70SS396 & 70 Malibu
My Car
"I don't drive FAST, I just FLY low!"
JungleJim is offline
post #4 of 11 (permalink) Old Jan 28th, 01, 10:09 AM Thread Starter
PART #'s please! Thanks
MStarmer is offline
post #5 of 11 (permalink) Old Jan 28th, 01, 10:23 AM
just go to a GM dealer and ask for a tube of black sealer...i love it and it work's better then the permatex s#$#t IMHO, i have used both.
ilbl8 is offline
post #6 of 11 (permalink) Old Jan 28th, 01, 04:58 PM
Am I the only one still using good old fashioned Copper Coat?
b-boy is offline
post #7 of 11 (permalink) Old Jan 31st, 01, 12:49 PM
Gm stuff is excellent, also "The right stuff" comes in a cheez wiz type can ive had good luck with that too but its expensive. It also depends where your going to use it on the motor, some sealers dont like gasoline
David R is offline
post #8 of 11 (permalink) Old Jan 31st, 01, 06:17 PM
Gorilla snot!
kz1000ltd is offline
post #9 of 11 (permalink) Old Jan 31st, 01, 07:08 PM
I prefer Permatex 3 Aviation Gasket Sealer. It's a quality product at a reasonable price (about $5 for a small can). Great all around gasket sealing compound for flat surfaces such as intake gaskets, pans, valve covers, outboard motor parts, you name it! But for the ends I'd use good ol' permatex blue or black. Works fine. Just personal preference as you can tell by all the replies you've gotten here. LOL
dellerbe is offline
post #10 of 11 (permalink) Old Feb 1st, 01, 08:38 AM
Big fan of GE II Silicone, Black, or clear available in a caulking gun at Home Depot, for short change.
Best silicone I've ever used.
68ragtop is offline
post #11 of 11 (permalink) Old Feb 1st, 01, 04:55 PM
i hear ya ragtop. everyone around here uses cheap old silicon around here on our dirt motors, and they see alky, must harsher than gas. We go out to the WAL-MART and buy DAP 50 year 100% silicone. Black or clear, makes no difference. It works just as well as permatex, or any other silicone type sealer, and it is only like 2.50 for a chalking gun tube.
racerboy3v is offline
