Moly Or Cast Rings - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 25th, 03, 03:22 PM Thread Starter
Lightbulb
I would like to get some opinions before I order my sealed power kit from Fedral Mogul. [img]graemlins/thumbsup.gif[/img]
metalchecker is offline
post #2 of 2 (permalink) Old Mar 25th, 03, 07:51 PM
Vintage 68's Avatar
Moly or Cast Rings start out the same.
Moly rings are cast then coated with a Molly-Metal coating to improve wear and reduce drag.
Cast rings are finished with the cast surface intended to do the sealing and cylinder contact. They are the most common ring in most OEM applications for older model engines.
I try to use Moly if possible - but, Cast work just fine. Stay away from Chrome for street engines.
1968 Convertible
Some trucks
Vintage 68 is offline
