won't start - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 1st, 05, 03:44 AM Thread Starter
I have put my car up for the bad weather but wanted to start it the other day. Battery is charged,tryed to start but nothing interior lights dim down and i hear a low hum. please help any thoughts. thanks jf
red-dog is offline
post #2 of 3 (permalink) Old Jan 1st, 05, 06:18 PM
Sounds like a starter or solenoid problem.
How old is the starter?
Giving the starter motor housing a few sharp taps with a hammer will sometimes give you one or two more starts out of it.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 3 (permalink) Old Jan 1st, 05, 06:40 PM
check that connection where your battery cable meets the solenoid first,then get to cleaning all electrical connections.if that doesn't help try tapping the solenoid with a "ford wrench".
baking soda mixed with water is a good way to dissolve corrosion.
a light coat of red spray high tack will help to keep tour fresh clean connections that way.
E
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
