FLAMES OUT OF A HOLLEY CARB. - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 15th, 03, 07:42 PM Thread Starter
My '68 Camaro recently developed a problem of flames fireing out of a Holley 650 double pumper. A mechanic told me I need bigger fuel squirters/ pumpers because the car hesitates from first gear. The flames from the carb. seem to be too much fuel. Thanks for the advice.
FLS68 is offline
post #2 of 3 (permalink) Old Aug 16th, 03, 08:02 AM
Flames out of the carb is a bad thing. How are your eyebrows doing?
I'd double check the timing. Also check your valve adjustment for a too tight or a stuck intake valve.
As it's a Holley, there is a good chance you've ruined the power valve by backfiring through the carb. I'd check that as well.
BPOS is offline
post #3 of 3 (permalink) Old Aug 21st, 03, 06:45 PM
Angry
Thanks for the help, no more back-fire, but idles too high. Must need to adj. timing again.
Thanks again!
FSL68 is offline
