RE: rear gears - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 30th, 01, 06:46 PM Thread Starter
I have a 69 SS with the stock 3.07 posi rear end. What performace percentage can I get by increasing the gears to a higher number (say 3.31). If there a formula to figure this out. I am looking for a general percentage because of all the factors involeved.
Also what effect dose the higher gear ratio have on the overall perforamce? Dose everthing you gain at the low end get lost at the top end (RPM). I know you gas milage will go due to running higher RPM's.
69 SS
Blk69 is offline
post #2 of 12 (permalink) Old Feb 2nd, 01, 02:12 PM Thread Starter
Hey does anyone know the formula for calculating the the gain with the high numbered gears? Hp/Torque
I would think the top end perfomace would seriously be affected my the higher numbered gears.
Blk69 is offline
post #3 of 12 (permalink) Old Feb 3rd, 01, 12:41 AM
Personally, I dont think you would gain enough from such a small change in gear ratios to justify the cost and effort. Your talking maybe a couple of tenths in the 1/4 mile at best. You could get the same effect by going to a slightly shorter rear tire.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #4 of 12 (permalink) Old Feb 3rd, 01, 03:17 AM
www.prestsge.com www.mortec.com
one or both may have what your looking for ?
as for the 3.08's to the 3.31's, will notice some differance,but the 3.55's would be a better choice , so i feel.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[This message has been edited by DOUG G (edited 02-03-2001).]
post #5 of 12 (permalink) Old Feb 3rd, 01, 08:32 AM
I have a new set of Richmond 3.55's for a 3 series 12 bolt, new in the box
Email me if interested
[This message has been edited by 68ragtop (edited 02-03-2001).]
68ragtop is offline
post #6 of 12 (permalink) Old Feb 7th, 01, 01:56 PM Thread Starter
I am surpised to hear that there is not a really diffence between the 3.07 and 3.31 rear gears. I am causious about going any higher on the gear ratio due to losses at the top end. Thank's for the input.
Blk69 is offline
post #7 of 12 (permalink) Old Feb 7th, 01, 02:10 PM
mccorry's Avatar
I went 3.08 to 3.31 and would say there is a SLIGHT difference....but the main reason was that I went from an open carrier to a posi.
Lemme know if you want any help...
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 2/3/01)
mccorry is offline
post #8 of 12 (permalink) Old Feb 8th, 01, 05:13 PM Thread Starter
Mccorry,
I have riden in your car before and it halls. I thought you had a higher then 3.31 rear gear. You changed your rear gear out yourself didn't you?
Bill
Blk69 is offline
post #9 of 12 (permalink) Old Feb 9th, 01, 12:54 PM
mccorry's Avatar
Yeah, Bill ...you've been in mine...with the 3.31's. I did the swap myself....
mccorry is offline
post #10 of 12 (permalink) Old Feb 9th, 01, 06:57 PM Thread Starter
Steve,
Do you know when the Springfield Spring swap meet is going be? Is it Memorial Day weekend?
Blk69 is offline
post #11 of 12 (permalink) Old Feb 10th, 01, 07:29 AM
Lonnie
Your 1/4 mile MPH, horsepower, will not be affected by gear ratio. It will stay within 1 mph.
67 Camaro 410sb 11.63 @117.6
67 Camaro 388 12.10 @110.6
website
Lonnie67 is offline
post #12 of 12 (permalink) Old Feb 10th, 01, 06:12 PM
mccorry's Avatar
Not sure of the dates yet...If I see em...Ill let you know...
mccorry is offline
