What is a 94 LT-1 worth? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 17th, 05, 02:21 PM Thread Starter
With all accesories, ECM, 4L60E behind it, and 150K?
YJLopes is offline
post #2 of 3 (permalink) Old Jan 18th, 05, 06:03 PM
Lee
have you seen the motor run? I have a 96 LT-1 with over 160K on it and it runs fine, but if they have been abused you might have problems. I would think though with all that is offered, you might expect to around 1k or just a little more. I would not give more than that because with 150k on it, it will need a rebuild (trans too) if you are going to lean on it. You can buy rebuilt LT-1 for 5k or so from some of the crate engine builders, so think about what you might be getting into.
Is it a corvette, camaro or Impala motor? That makes a difference too. The Impala motors have cast iron heads and thus should be a little cheaper.
69Project is offline
post #3 of 3 (permalink) Old Jan 24th, 05, 01:22 PM
I am selling a 94'LT1 out of a Z28 if you are looking?
69_SS_RS is offline
