What is this tube? Holley Question - Team Camaro Tech
post #1 of 6 (permalink) Old May 15th, 04, 06:01 PM Thread Starter
I rebuilt a used Holley 700 DP, but it has what looks like a brass vacuum tube screwed into the side of the primary metering body above the idle adjust needle. What do I do with it? Is it a vacuum line? does the carb need it?
kdaniel is offline
post #2 of 6 (permalink) Old May 15th, 04, 06:48 PM
Royce
It is a vacuum port, if it's the tube I am thinking about, is it adove the idle mixture screws? If so that should be a vacuum port.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 6 (permalink) Old May 15th, 04, 07:07 PM Thread Starter
Correct, It is right above the idle adjustment screw. Do I need it? Should I cap it or connect it up to vacuum? What effect does it have?
kdaniel is offline
post #4 of 6 (permalink) Old May 15th, 04, 07:23 PM
ZZ_430's Avatar
That is a ported vacuum source. Depending on your set up, you can use that for your distributor vacuum advance.
You could either run manifold vacuum from the port on the baseplate for the distributor, or plug it.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 6 (permalink) Old May 17th, 04, 03:22 PM
If you wind up NOT using it, be sure and plug it!
BPOS is offline
post #6 of 6 (permalink) Old May 17th, 04, 04:23 PM Thread Starter
Thanks all. [img]graemlins/beers.gif[/img]
kdaniel is offline
